Barnes & Noble nook color eBook Reader Logo
Posted on Sep 07, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cant remember my passcode how do i reset nc - Barnes & Noble nook color eBook Reader
Anonymous
Level 3:
  • Master 1,188 Answers
  • Posted on Sep 07, 2011
Anonymous
Master
Level 3:
Answers
1188
Questions
0
Helped
355820
Points
3656
The following procedure details the process to Hard Reset your NOOKcolor device. Doing so will perform a factory reset of the NOOKcolor which de-registers your device as well as erases all local content such as contacts, sideloaded documents, personal information, 4 digit passcodes, etc. 1.Ensure your NOOKcolor is powered off; to do so, depress the power button for 5 seconds. Your LCD screen should turn off
2.With your NOOKcolor powered off, Hold the Home Key (NOOK "n," logo below the LCD), while simultaneously depressing the Power Button for up to 25 seconds.
3. Your NOOKcolor will begin the start up process, Do NOT let go until a confirmation window appears asking if you would like to, "Factory Reset Your Device?" This will De-Register as well as erase all content and information on your NOOKcolor (Including the 4 Digit Pass-code
4. Depress the Home Key to continue with the Factory Reset
5. Depress the Home Key again to Confirm
6. Your device will now begin the clearing process. Upon completion you will regain access to your NOOKcolor however all account and personal information (email, contacts, pass-code, credit card, etc..) will be deleted from your device. You will then be able to Re-Register your NOOKcolor and start anew. Good luck!! EJ Kudelka
Forgotten passcode how to reset my password on my kindle paperwhite
You may want to follow the instructions on the Amazon web site below:
https://www.amazon.com/gp/help/customer/display.html?nodeId=201176220
"If you can't remember the on-device passcode for your Kindle, you'll need to reset your device.
If you do not remember the passcode for your Kindle, you'll need to reset your device, which will remove all of your personal information, including your lock screen passcode and parental controls, Amazon account information, Wi-Fi settings, and downloaded content.
Any content you've purchased from Amazon is automatically saved to the Cloud and can be re-downloaded when you register your Kindle to your account again.
To reset your device:
  1. Tap the passcode field to bring up the onscreen keyboard.
  2. Type 111222777, and then tap OK.
To use your Kindle again, you'll need to connect to a wireless network and register your device."
Forgot pin number for my kindle fire.
If you can't remember the passcode for your Kindle (not your Amazon password), you'll need to reset your device.
  1. Press the Keyboard key to bring up the onscreen keyboard.
  2. Type resetmykindle into the passcode field, and then use the 5-way controller to select Done.
  3. Select ok with the 5-way controller.
Need a new password for my kindle
  4. Besyofluck!!!
2answers
I cannot remember my password for my kindle
Hello Friends...
If you can't remember the passcode for your Kindle, you'll need to reset your device. Press the Keyboard key to bring up the onscreen keyboard. Type reset my kindle into the passcode field, and then use the 5-way controller to select Done.
For any help visit us: Kindle Fire Support
Set it up with thumb print when Iopened it up wont let me in without 6 digit passcode which I don't have
Well, when you first set up your IPad you had to create a passcode to get in. If you can remember what your passcode is click the link here and reset it. Forgot passcode for your iPhone iPad or iPod touch or your device is...
2helpful
2answers
Reset 4 digit lock code for iPad 2
Hi John,
If you cannot remember your lock code, you will need to restore your device as new or be able to restore a backup if you cannot remember your lock code.
If you do remember your lock code you can update it in the settings app:
Click on Settings and then scroll down to the Passcode option (you may have to scroll down a bit). This will bring you to the Passcode Lock menu where you can turn off or update your lock code.
Hope that helps!
Cant remember my passcode for my ipad
plug it into the original computer that you set it up with and through itunes you will be able to reset it. Once the ipod appears under devices click on the restore button it will indicate that you can restore settings etc. If it is not the original computer that you are using you will be able to reset it but will lose the information on it. Hope this helps.
Top Barnes & Noble Tablets & eReaders Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
ADMIN Andrew
ADMIN Andrew
Anonymous
Level 1 Expert
Are you a Barnes & Noble Tablet and eReader Expert? Answer questions, earn points and help others
